New PSU!
SimenGaming
Hi!
I'm looking for a new PSU, and was wondering what would be the best alternative.
I need a fully modular PSU because I plan to sleeve, and it must be enough wattage to run cfx/SLI. And I wouldn't mind one of the longer PSUs to fill up my case with. What I've looked at so far are some PSUs from Corsair, Seasonic, Thermal Take and EVGA, but I have no idea what to go for.
Do you have any recommendations?
Thanks!^_^
my Corsair AX750 should arrive tomorrow, it has sleeving and you can order custom sleeved cables as well (idk if they sell those in norway, i intended to buy those, but i would need to import them from the UK which would double the costs :(. ) should definitely do the job, for sli either the 850W version or the 1200W if you really need it.
Yeah, I know they got the sleeved cables at the webstore I use to buy from, but part of the fun is sleeving yourself:p
Du trenger strengt tatt ikke mer enn 750W. Jeg ville gått for den nye Corsair AX760, alternativt AX860. Disse er i realiteten Seasonic Platinum med Corsair logo. Samtidig kan du spare litt på å velge "den gamle" AX serien på 750/850W.
Dustin Home har ganske ok priser.
I don't know your specs but unless you have a ridiculous quad fire/sli setup an AX760i from Corsair should be more than enough, its fully modular as well :)
Takker for svar, på norsk til og med^_^
And thanks for all the other replies!:D
uhmm. if you really want a nice PSU.
then buy a Cooler Master Silent Pro Hybrid 850W
It's the best PSU i ever had. So extremely silent and 100% modulair.
Specs:
http://www.coolermaster.nl/product.php?product_id=6743
Always when someone talk about COOLERMASTER 850W SilentPro Hybride I will show this. 30$ more...
http://youtu.be/1yEsB0jZYTU xexexe
CM Silent Pro Hybride 850W Gold - Price 199$
Seasonic SS 1000 XP Platinum delivery 1300W on video clip above, 12V rail not move Price 229$.
CM hold monopol in my country, you should se how that look. No Enermax, No CORSAIR, No Seasonic Gold and Platinum Nothing. If my two PSU die I swear I will stay without PC until find what I need I will not pay to them.
