new power supply for a new graphics card
trazomfr
hello friends
I look forward to the results of Tom about the new GTX 590 and I think to buy one. But it will require that I replace my 650W power supply in my opinion. I am very pleased with the Corsair power and I would stay with them. But I do know that buying: AX 850 or AX 1200? I do not do SLI, I will not have the financial means and I think overclock my Core i7 920 for it does not restrict the performance of the graphics card.
Thank you for your advice.
hello friends
Then the ax850 and the price difference is small between the HX serieds and you wont regret on the ax850
Thank you for your reply. I was not certain that a 850W power supply will be sufficient to power a GTX 590 + overclocking.
Here I am reassured thank you.
