New phone - choices
Got a desire coming tues
£20 a month
direct with orange
400 mins
ultd texts
500mb of data
not too bad!
Normal desire for the following reasons
It has a larger battery MaH
Same resolution screen (the HD is misleading as its the same DPI just stretched out on a bigger screen = less sharp than the normal desire)
Possibility to get a cheaper monthly deal
annd
that bigger screen will probably use more battery, but the main reason was they were outta stock for a week - not much between them tbh
the desire hd is very sexy looking tho
i am wit you mate the desire is my next choice i dont follow the trend of iphone and BB bold
the desire is alot better with the UI yes the iphone has a few little quirks and is faster but marginal
the galaxy s is also another of my faves its biggest downfall is the tackyness of it
Yer too rioght mate it's a shame I still have to wait about 6 months till I can get myself a proper phone instead of this Samsung Jet (piece of junk :S.)
If I were to get myself a phone right now it'd probably be a Desire HD or an iPhone 4, since they both look uber smexy (I'm a sucker for looks
) and perform great, aswell as being user friendly
Had my desire a day...have already and rooted/debranded it from the stock 2.2 orange firm bloatware ^^
Now running generic 2.2 froyo
Been using it all day and already ran it down hehe
Some tweaking is in order...maybe an after market battery
The n8 isnt that bad, but its not amazing for the money, it can get a bit sluggish on the 680mhz cpu with a bunch of crap running but other than that its ok for me, if it had the same cpu as the desire HD or even the Desire Z it would be a bunch better.
Feature set wise the Desire HD wins out no questions asked tho.
1400mha would be better
I can get a 1600mah battery which will fit the same size...would this make much difference...
or a 2600mah with different battery cover...not sure if it will fit the case tho
i would just get the highest that fits stock batt cover fella
1400mha would be a big improvement fella
so yer 1600mha would be alot better,it would take longer to charge tho as the charger is made to charge the stock batt.but u get longer usabilty
