New Gaming PC Build... Will it work?
BlazingWaterz
Hey guys
I'm currently gathering a parts list to build my first gaming rig, I have a final spec, but just want to double check if it'll work...
-Asus M4A79XTD EVO 790X Socket AM3 8 Channel Audio ATX Motherboard (for later CrossFireX)
-Coolermaster CM690 II with Coolermaster GX 650W PSU
-Sapphire HD 5770 1GB GDDR5 (One for the moment)
-AMD Phenom II X4 965 Black Edition 3.4GHz Socket AM3
-Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
-Kingston 4GB (2x2GB) DDR3 1600MHz HyperX Memory Kit CL9 1.65V XMP
-Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1366, AM2, AM3 Heatpipe CPU Cooler (overclocking the Phenom II 965)
Thanks guys, it all comes to about £515
The x4 955 will be enoguh, just overclock that.
I would buy at least a Mugen 2 cpu cooler and i personally wouldnt recommend crossfire with 5770. They arent strong enogu. Get at least a 6850.
About £500, I looked at a £400 setup, but that will barely last me a year or two, £500 seems the hotspot.
New Spec i've come up with is...
- AMD Phenom II x4 955 (3.2ghz will be at 3.8ghz-4ghz overclock)
- Coolermaster Centurion 5 II Case with Coolermaster GX 550W PSU
- Kingston HyperX 2x2gb 1600mhz
- Palit SONIC GTX 460 1gb (I will overclock this)
- Asus AM3 M4A88T-V EVO
- Coolmaster Hyper 212 Heatsink
- Samsung Spinpoint F3 1TB
Thanks! It's all about 498 quid.
What about an AMD/ATI HD6870 instead of the 460, also gives you the option of Crossfire later on.
RAM: Maybe look into Mushkin Silverline, I think it's slightly cheaper, but it will perform just as well. Also looks a lot prettier.
