New Gaming Build (New Final Thread)
MattBee2k2
Ok I've went with all the tips and want to know if there could be anymore changes but I doubt it, quite happy with it.
MSI GeForce GTX 580 Lightning - http://www.overclockers.co.uk/showproduct.php?prodid=GX-124-MS
ntel Core i5-2500K - http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
Asus P67 Sabertooth Intel P67 - http://www.overclockers.co.uk/showproduct.php?prodid=MB-449-AS
LG Flatron W2261V-PF 22" - http://www.overclockers.co.uk/showproduct.php?prodid=MO-075-LG
Coolermaster HAF X - http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM
Noctua NH-D14 Dual Radiator - http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC
Saitek Cyborg V7 Illuminated - http://www.overclockers.co.uk/showproduct.php?prodid=KB-046-SK
Samsung SpinPoint F3 1TB - http://www.overclockers.co.uk/showproduct.php?prodid=HD-082-SA
Kingston HyperX Genesis Grey 4GB - http://www.overclockers.co.uk/showproduct.php?prodid=MY-095-KS
Coolermaster Inferno 4000dpi - http://www.overclockers.co.uk/showproduct.php?prodid=BU-003-CM
Samsung SH-S223C/BEBE 22x DVD±RW - http://www.overclockers.co.uk/showproduct.php?prodid=CD-099-SA
Corsair Professional Series AX850 - http://www.ebuyer.com/product/227503
Changed the 2600k to a 2500k, changed to a corsair AX850 and changed that monitor to LG plus the specs are better on the LG one.
But as for cases, which one would be better spec wise and air flow and spacing wise (including 2 gtx 580's)
the HAF x or this http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-CS&groupid=701&catid=7&subcat=
why only 1 hdd ? i suggest you get an ssd or raid 0 array when you install windows for the first time, saves you a lot of trouble later on when u want more speed
IMO a ssd is kinda a waste of money im not too bothered aboot a instant windows boot just as long as its quick, I mean I currently have a p4 with 1gb of ddr ram and a 5400rpm hdd I think and the boot up is rather fast so with that new system it'll be fast enough.
If later on I decide I want one I'll probably get one.
Only thing i would change is the kingston RAM get some mushkin inside there
Done that now, Aria have it overclockers don't
I also decided to go with the 650D after looking at reviews and other stuff plus the HAF X window is rubbish. I was thinking of the 800D but no need for it plus it's a little dear so the 650d is just the same but smaller.
