Huusa
Basically i just want to upgrade my pc, currently i have these specs:
Processor: AMD Phenom(tm) II X4 960T Processor (4 CPUs), ~3.0GHz
Memory: 8192MB RAM
Hard Drive: 120 GB laptop mechanical turd drive
Video Card: AMD Radeon HD 6850
Operating System:Windows 7 Professional 64-bit
Motherboard: ASROCK M3A770DE
Computer Case: Inwin griffin
Power supply: CiT 650w
Its done a good job running 24/7 for over a year and for only £240 but i haven't taken care of it and its falling to pieces, the front panel is just a big hole and its full of dust.
All i use the pc for is playing counter strike and browsing the internet so it doesn't need to be top spec i just need 300fps which my current pc can just about manage. This is what i have come up with so far:
BitFenix Prodigy
ASRock Z77
Corsair cx750
I5 3570
Samgung 128gb ssd
7870
8gb Corsair Vengeance 1600
I'm no good with building computers so i don't even know if it all fits together but at the minute i think its a little over kill and id like to spend a less if possible. Should i maybe get a cheaper GPU and spend the money on better power supply? Also even though the case is not too expensive would it be cheaper to use a mid tower rather than that unusual thing, i just thought maybe there would be more choice of Motherboards.
I have a cd drive already and i don't think i will need a hard-drive for storage because i dont store things that i don't need
Memory: 8192MB RAM
BitFenix Prodigy
ASRock Z77
Corsair cx750
I5 3570
Samgung 128gb ssd
7870
