it's the other way around![]()
LGA2011 (Ivy bridge) will be the new 1366 (i.e. enthusiast) platform. Bulldozer will probably be more of a budget system like sandy bridge is. Or atleast that is what I understand to be preolt's statement.
Thats what I was trying to say, hmm might need to reread what I tried to tell him. Any way your completely right. AMD has always been the budget cpu company marketed towards low end builds or gamers who dont care about raw cpu horse power. Now this doesnt mean that you cant achieve some torque from their cpu line up but even then it tends to be from their "mid range" models. Really hexa core is all fine and dandy sounding but until companies start putting out main stream software the supports the 6 core hardware then they are not needed.
Most would say go AMD on a budget but if you can afford intel then you shouldnt even be asking about AMD. I have built AMD rigs in the past and they are solid pc's. But they can never seem to compete with that of intel and SB just drives that home. SB sort of stole part of AMD's customer base because intel has chips now like some of the i3s and the i5s that are as fast or faster then amd's top level offering (i5-2500k) faster then any thing AMD has to date in any thing) Bulldozer might change this but I am a bit doubtful. I was astounded by intels SB jump in speed. But I also believe that is do to the fact that they screwed some thing up on the lga 1156 and lga 1366 socket cpu/mobos, I find 1 year hard to believe from a business economic stand point unless there is a design flaw in your product..
Done ranting and weaving my thoughts into that ha. Any way, Ivy bridge is basically intels new high end offering. It will be replacing chips like the bloomfield and up (i7-950+) they will range probably from 500-1000 dollars in price I would think, but thats just an estimate. Now is an awesome time to build though because the i5-2500k and i7-2600k are faster then intels current extreme edition for the 1366 socket. Btw just a quick note 1366 was never a "main stream" socket, it was and still is considered the higher end gamer enthusiast choice for people with larger budgets. i5 is king when it comes to enthusiast level products.
