new case !!
giannakos23
Hi guys,
I want to change my switch 810 because it is too to fit in my room ...
Can you recommend me another case that has radiator support ??
I'm between the phantom 410 and the 600t !!
Thank you in advance !!
i wouldnt buy either of them if you want to watercool something properly, 650D or a CM 690 II (if your going for dual rads) would be more suitable maybe even a haf 932
As said above the 650D is essentially a 600T but with better watercooling capabilities so i'd go for that if you were wanting a 600t
maybe the checkout the gunmetal grey 600t watercooling guide by ttl if you're set on it, may give you a few ideas to think about
I know that the 650d is a better case than the 600t when it comes to watercooling but I don't like the way it looks !! I would like to go with cooler master cases but the lack of a side panel window annoys me quite a lot !!! I've seen the modding guide that Tom did and that's why i'm between this and the phantom 410 !! In the 410 you can fit 2 rads with a little bit of modding and it is 60 euros cheaper than the 600t !! So what do you recommend now ???
Support for what rad. The corsair doesnt support rads properly out of the box IMHO - neither does the 410 without work.
Yes I know that but I would like to try my modding skills !!! Do you have any other recommendations for cases with watercooling support ??
