Treble20
Hello guys and gals,
I thought I would try to do a bit better build log this time as my last one appeared to go down quite well.
Previous Builds :
Foundation
http://forum.overclock3d.net/showthread.php?t=48059
Exile:
http://forum.overclock3d.net/showthread.php?t=57836
Also Taken some of the wife's advice and taking my time more with this one and I don't mind saying it is driving me nuts.
I will be cannibalising my previous build (Exile) and using the CPU Water block,RAM, Some fans, PSU,Pump, Rigid Tubing fittings, Two SSD's (Will add a third to the raid 0) Sound card as imo its still a good one, Mouse keyboard and monitor. Also able to reuse the old GPU water blocks and just swap out the perspex so they fit the new GPU's
I was lucky enough to win a silver Award in the Corsair Dominator competition and will be getting a new RGB Mechanical Keyboard when they are released. and a new monitor when I decide what direction to go possibly the PG278Q.
Will Be going with a more dominant white theme and changing up to a Z97 chip-set, The Asus Sabertooth mark 1 Motherboard and i7 4790k cpu. The GPU's will be replaced with EVGA GTX 780ti's. Case will be a larger one as Going for the Enthoo Primo in White. Will be changing out the res for an EK one and Water cooling the RAM ( just for looks) and bigger RADs.
Anyway Will post as many pics as can (within reason) and as usual Questions,compliments and constructive criticism is welcome.
All the best and thanks for checking it out.
Previous Builds :
Foundation
Exile:
