Wondering if anyone can help me please! Basically its my first computer build a sandy bridge i5 2500k, asus p8z68 pro gen 3 motherboard ripjaws 2100 ram, a crutial m4 64gb ssd, gtx 580 and a hx 850 psu.
I built the computer which booted fine into the bios, installed windows 7 then went on to perform a overclock.
Went for 4.5ghz and found it stable running prime95 for 12 hours with no errors.
The next time I turned on windows the computer crashed after loading windows.
After restarting the computer ran fine but then crashed again next time I turned computer on in windows.
So i thought the fault might be in the overclock so I reset the bios to the asus bios from there website which I thought had done the trick until it crashed after the computer loaded windows yesterday.
Now the computer is not even loading bios it appears to be running fine when I turn it on but no signal through t.v atall. Looked at the motherboard and no error lights are lighting up.
Really don't no what to do as this is my first build and im sick of it after spending so much on parts
Might have to take it apart and start again!
Any help would be hugely appreciated as I don't no what to do and im so frustrated! Or anyone that could advice me where I could find out?
Thanks to any replys!
