new build freezes every time watching you tube sad:( help pls
alvin
any suggestions?...
Rig is 3930k,asus rampage IV formula, [font=arial, sans-serif]Mushkin 16GB 2133MHz Quad Channel Kit 993997,120gb [/font][font=helvetica, arial, sans-serif]Corsair Force Series GT, 64bit window 7 ultimate, XFX 1gb 4890, Corsair AX1200, HAF-X...[/font]
Gaming never freezes at all, but it does few second watching YOU TUBE... every time de-power revive's it then try watching it again freezes so sad no clue what do i need to do...
Welcome
Which browser are you using mate? Do you have this problem with a number of browsers or with just one? But as hmmmblah said disable GPU acceleration.
Are you using Chrome? If so check to see if there's any updates available. I know a lot of people had freezing issues when watching videos with Chrome before, i had it too until they updated it. Alternatively, disable GPU acceleration as mentioned above.
Welcome to the forums buddy, although you've posted your question in the wrong place, this is the introductions thread
