Gravan
Hai All,
I'm a 1st time poster but a v.long time viewer. I came across in the good old TJ Harlow days
I'm looking to put a new build together & wondering if you would not mind checking that I have not missed anything, or should I look at changing something.
Colour concept is Red & black as that will suit most of the components. I am thinking of incorperating UV to show off the w/cooling. just not 100% sure as I have not use lighting within a case before. Otherwise I will just use red coolant & red lighting.
Once setup I am intending to have a balance between Noise & O/Clocking, ie O/Clock until it gets too loud & hot
Case: Corsair 650D - Would have loved to to use the white 600T but could not easily W/Cool it
, Also considered the Silverstone RV02 & FT02.
Fans: Switching out original fans to the following - for noise & colour
3 x Bitfenix Spectre Pro 120mm red tint
1 x Bitfenix Spectre Pro 200mm red tint
CPU: Intel i7 3930K
MB: ASUS Rampage IV Formula (Was thinking of using the Gene - but could not see any advantage, & could not see the $/ return benefit of the extreme)
Memory: 16GB G.Skill Ripjay Z F3-14900CL9Q-16GBZL (is there any point considering the 16Gb of the F3-17000CL11Q ? no price difference )
PSU: Corsair AX850
Storage: 2 x Corsair Force GT 120GB (in Raid 0)
1 x WD Caviar Black 2Tb
GPU: Asus HD7970 DCII
CPU cooling: XSPC Raystorm D5 RX240 water cooling kit (the RX will fix in the top of the 650D)
Koolance Fluorescent red (Still not 100% sure if I should go UV or plain red as I have had no experience in that type of lighting)
F/Controler: Lamptron FC6 (Not sure about this either - just looking to control fan speed, maybe pump speed, & turning the lighting on & off)
Lighting: Using 2 x 30cm Bitspower UV Cathodes (Any idea how the UV & normal red LED lights will react with one another?)
Also utilising Bitfenix Red cable extensions
OS: W7 64bit Prof
K/Board: Corsair K90
Mouse: Corsair M60
Monitors: 3 x ?? Something to look foward to in the future
Was thinking in the future to Water cool the GPU, but I'm thinking that is way off
Current cost is approx $3500 AUD ex Freight. Luckily enough it is all from one supplier hopefully should keep the cost down.
Restasured once I get approval from the Boss (Wife)
, I will post some pic's of my new build.
Your thoughts and comments would be much appreciated.
Grav
CPU: Intel i7 3930K
PSU: Corsair AX850
OS: W7 64bit Prof
Mouse: Corsair M60
Grav
