Never tried water, HALP
Ghosthud1
Right! I've basically decided my PC is up to spec and doesn't need anything more than cooling upgrades...finally.
I'm looking to get into water cooling my 3570k but I have no idea what im doing.
I want someone to talk to me like im 5 :lol: i wont be offended.
I'm currently using a HAF XB and would prefer to keep this case as it sits perfectly in the side of my desk.
The only possibly inconvenience would be the GPU'S 140mm fan...it kinda touches the front of the case removing the choice for a 240 in the front. :mad:
I could change it out for 120's though...hmmmmm.
Budget is around 150 for just the CPU loop.
I have a universal block on my 7870 Tahiti and it works fine and looks ok imo, as for a waste of money I don't see how as you don't have to get a new block everytime you get a new GPU, I used the same block for my 6870 :)
Back on topic for £150 you will have problems getting a proper custom loop, tbh if all your looking at is doing a cpu only then you may as well look at getting one of the AIO
That's a good kit for cpu if you want to add a gpu you would need extra rad space. I have an EK rad and gpu block in my loop and they perform well enough :) and quality is good
Please give credit where it's due. Just cause some review goes up on this website doesn't mean Tom did it. The author of that article was Gary Wain.
Go for the cheapest 240 kit you can find out of the 4 that was tested and stick the sp120s on em. problem should be solved for the cpu.
I always give credit and I've been here long enough to know we have different people within the reviewing crew. I just guessed it was Tom because i thought he did a video on this which he actually didn't.
And I just ordered the EK kit as it seems more compact than the rest.
