whats the name of the software??? can you temp put a drive in??
give it to someone to make an ISO image and mount that one using daemontools or whatever...
for ghosting it can be the cable is too close to a power cable try move it? or try another or new cable sometime they are not shielded properly.
i had the same problem with a DVI cable went and got a new one and it fixed it.
