Hi,
I think it might be remembering your prior manual setting of the vCore. I generally restored everything to default when I was changing
how I overclocked.
I'm not saying what you've done is wrong in any way, it's just slightly different to how I did it. Remember that there may also be difference between how our (albeit similar) boards do things. My understanding is that the Z68 Pro's and P67 Pro's from ASUS as very very similar in regards to BIOS settings.
For me it was very much a learning process, trying things different ways & saving profiles when I hit a sucessful overclock. For example I have a couple of "4.5ghz" profiles on my machine, each achieving a similar result but done
slightly differently. This is how I learnt.
My first 1155 mobo was a cheap one and had VERY limited options and was not a good overclocker...I got to 4.5 without too much issue but the board really couldn't control the vCore very well so it ran hotter than it should. Moving to the Z68 from ASUS I achieve 4.5 more readily, at a lower vCore and a correspondingly lower load temperature.
I think you're doing well, I'd recommend saving your successful overclock to a profile and trying things another way (after restoring defaults) if you're inclined to. This way you can always easily record each step in your OC process as a step away from Default.
To be honest, with Sandy B. and this particular board my FIRST OC was easy. Set multi of 45, changed nothing else & reboot! Ok, system wasn't stable under load but I got to windows and could do undemanding tasks right away. Benching and stressing allowed me to refine things, i.e. a bit more vCore via offset mode, bump up the LLC to get a stable 4.6 etc. etc.
Just keep an eye on your temps, I personally would be uncomfortable at anything over the mid-70's in IBT, but remember that IBT really does push your CPU harder than anything else, so day-to-day activities and gaming will be a good 10c below this level - again, in my experience.
I'm a little OCD when it comes to getting my OC perfect in my mind, whereas a friend of mine just adds an obscene amount of vCore and leaves it at that! Lol. Being on bespoke water, you can maybe be a bit more blaze regarding vCore as temperatures remain good...but that's not quite how I do it.
Part of the fun is finding out what works for you
Btw: can you confirm that your CPU is idling to 1.6ghz and that your vCore drops accordingly? In my experience (limited, I don't buy lots of new kit or review it!) setting vCore directly stops it reducing when the CPU idles, setting it via offset however allows it to drop at idle - which is great for your temps when you're just doing desktop stuff.
Sorry, I know sometimes this stuff can feel like information overload...I've tried to keep it simple in my own experimenting by changing just one thing at a time and restoring from defaults when trying a different approach.
Cheers,
Scoob.
