SwaleSmith
Hi,
I am currently working on a build in a TJ07 have mounted a quad wich will be cooling the CPU and hopefull tommorow a 240cm double rad wich will be cooling 3 gtx 280's, room is very tight and am now at a fork in the road.
So my question is which direction would be best for the 2x 12cm fans go on the 240cm rad please see my make shift diagram below.
Please be aware that the fans must be mounted in the exact spots as shown due to the following reasons
1) my intention is to have the 4x 12cm quad fans glowing blue through the side panel grill
2) The fans on the 240cm rad must be on the right side due to the very tight limitations of giving the 4 hoses enough room, It will be impossible to use angled hose connectors with the fans on the left side.
please also note that the fans on the quad rad are sucking in from left and expelling towards the right.diagram below thanks....
