shambles1980
Hi.
so my haf 922 is to short. and if i want my top mounted 240 to clear my ram retention clips. i need to use 12.5 or possibly 15mm thick fans. (i would probably get 12.5 if possible just to be extra sure they will clear)
I have had a look arround but cant really see any that arent simply for air flow.
I could mount my current fans on the top of the case outside of it but i really dont want to do that.
Because the fans will be exhausting air in a pull setup i dont need them to have any fancy led's
they dont need to be overly crazy in power either i think this rad is 10-14 fins per inch so the static pressure doesn't need to be that extreme either.
3 pin or 4 pin fans are fine too as i use Speed fan for my fan speeds and it can even control 2 pin fans if needed. so not an issue there.
any way thanks in advance.
=#edit#= I bought the 12mm fans i found.
