Need help on 4k gaming build for $1500
MohammedNaleye
I will be upgrading my build for this. Will this be able to last for future games and will it be able to play games such as BF4 and Crysis 4 on ULTRA settings&60+ Frames? Should I upgrade to a 780 ti or a 880/ti next year or add another 780 in SLI?
I heard that the 290x is better than the 780.
Is this true?
Build:
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($333.98 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.98 @ OutletPC)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($199.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1866 Memory ($81.99 @ Newegg
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($59.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($56.99 @ Micro Center) Video Card: EVGA GeForce GTX 780 3GB Superclocked ACX Video Card ($479.99 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($99.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Total: $1512.86
Hey, if I were you I would wait a bit before going all out on a 4k gaming rig, at least until next month or so!
Also if you cut back on the i7/mobo you could get a better GPU, which would give you a performance increase if you're just gaming, but if you'd like to stick with the i7 please get the 4790k as it's the latest one :)
If you really want 4k, you prettymuch need to do sli or crossfire and even that will not render games on full settings on 4k, might i suggest you go with a 2560x1440 screen instead, 4k gaming isnt ready.
Take a look at the following review, it pits two 780Ti cards in SLI against two R290X cards in crossfire and benches them on a 4k 60hz monitor.
http://www.eteknix.com/4k-gaming-showdown-amd-r9-290x-crossfire-vs-nvidia-gtx-780-ti-sli/
Bear in mind one card can not provide adequate frame rates on a 4k screen to be considered playable, unless you massively drop the in-game visual settings. And then there's no point because 1080p with all the eye candy up full will look better than 4k at lowest settings.
Is this true?
You need 4 x 6gb cards to run Crysis 3 on ultra settings @4K and then you also have to overclock them a bit.
BF4 is a bit easier as you need 2 x 4gb+ cards and avoid Mantle unless you want to run out of VRAM.
The best option is to wait and see what the next gen of cards bring.
