Okay, first off, it's been a while since I last posted, to hello again
Here's my problem:
I currently use an am2 rig, and as much as I like it, I have just, (for the SECOND time with this mobo!) lost one of the little plastic nubbins on the cpu socket that most coolers clip onto. (It literally tore off over time, despite the cpu cooler not actually being a tight fit, or overstrained etc.) I'm sick of having to use coolers that rely on this feeble bit of badly cast plastic in order to stay in place!
So what I'm essentially looking for is a decenty priced CPU cooler for am2 CPU's that COMPLETELY bypasses the crappy stock plastic surround and uses a "bolt through" or similar design.
Thermal performance doesn't have to be great, It just needs to not cost the earth, and be at least as good as a stock cooler, whilst using a retention mechanism that DOES NOT use the standard crappy plastic nubbin/stupidly overtight clip system.
Also, as much as I may seem like a rambling idiot, I don't need any technical advice, I just want suggestions for coolers!
Thanks,
Matt.
Here's my problem:
Thanks,
Matt.
