siravarice
Changed my screen name from SIRAVARICE (yeah, that cocky one that gets banned a lot) to SiLo. Mainly because it's shorter, easier to remember, and it's the first two letter from my first and last names
Go to My Settings from the little drop down box in the top right. Its like the third one down or something on the left menu.
And that's the plan Tom! It's all just to confuse you! XD
Change Display Name
Depending on your permissions, you may be able to use this tool to change your display name which is used across the community.
