Hi
Ok so Ive got round to picking out the Kit That i need, But not all of it. I will list what ive picked so far.
EK CoolStream XT 360mm Triple Radiator : XT 360
http://specialtech.co.uk/spshop/cus...-360mm-Triple-Radiator--XT-360-pid-10694.html
XSPC RayStorm CPU Waterblock (Intel)
http://specialtech.co.uk/spshop/customer/XSPC-RayStorm-CPU-Waterblock-Intel-pid-14598.html
Koolance VID-AR687 Full Cover Waterblock for the ATI 6870 Graphics Card : AR687
http://specialtech.co.uk/spshop/cus...-ATI-6870-Graphics-Card--AR687-pid-12686.html
Phobya DC12-260 600LPH 12V Compact Pump
http://specialtech.co.uk/spshop/customer/Phobya-DC12-260-600LPH-12V-Compact-Pump-pid-10314.html
Phobya Balancer 150 Reservoir Black Nickel
http://specialtech.co.uk/spshop/customer/Phobya-Balancer-150-Reservoir-Black-Nickel-pid-11354.html
Bitspower 1/4" Thread Barb Fitting for 1/2" ID Tubing Matt Black : BP-MBWP-C01
http://specialtech.co.uk/spshop/cus...Tubing-Matt-Black--BP-MBWP-C01-pid-11248.html
Ok so thats what Ive picked so far, do you think the 360mm rad will be enough? A friend was saying to add another 120mm Into the Loop as i have a GPU on there too?
Im sitting at 4.6ghz on my cpu with only a 60c max temp hit at the moment with an antec 620 khuler.
Also Im looking at Mayhems Pastel Fluids, what else do i need for the fluid like biocides and kill coils ect?? or is the fluid straight ready to use?
Any suggestions to other parts welcome!
