My slice of heaven
Blade of Grass
Hey guys,
I'm relatively new to the forum, mostly been lurking, and I thought, why not show off my slice of heaven... Also known as the only room in my house away from siblings.
_DSC2573 http://www.flickr.com/people/wch-imaging/on Flickr
and a closer of my rig.
_DSC2580-3http://www.flickr.com/people/wch-imaging/on Flickr
I can also take some more pictures from closer of the rig if anyone wants, since I changed the layout a bit from the picture.
Oh, and also that god awful windows is going to be gone with a clear one ASAP.
Very nice. You should replace the window on the c70 with a plain one if you're not using the intake, looks much better :)
Welcome to the forums! :)
Nice looking personal slice of heaven you have there, it is looking fantastic.
I have to admit I love the shape and looks of your case. The big window is a plus but the fan mounts almost spoils everything. ( hopefully you take this as constructive criticism, not insult ).
They most definitely do spoil the look, agree 100%.
is it me or does the window look weird? i never thought the fan grills would be towards the hdd section, always thought they were pointing over the graphics cards
I'm using a CX70 as well and the fan mounts in the window are actually on the other side :p
(Not replacing the window since it helps a tiny bit with heat removal for my 100% passively cooled PC ;) )
Amazing rig, setup on desk and pictures :)
I'm starting to like the look of the case the more i see :)
@dipzy: yeah, that case grows on you, really. The one thing I like the most is the restart button though :p
(It's like you're launching a nuclear missile. ;))
Love the case. I have one coming from Tom as part of my prize from here. I have a ton of plexi, so I'll be measuring up the window. I'm gong to test a piece since it would have to be polished.
Very nice mate . I've always had a soft spot for the C70 . Not sure what it is , maybe the nuclear launch button . :microwave:
How is that R.A.T. mouse? I'm on the edge of buying one.
I had a rat 9 it lasted about 2 months the sensor started goin nuts and then I destroyed it completely :D anyway I wouldnt recommend one
Sorry for jacking the tread very nice rig cant wait to see it with its new and improved window ;)
Looking godd mate.
Sorry for jacking the tread very nice rig cant wait to see it with its new and improved window ;)[/QUOTE]
What do you mean by nuts mate ? I've got the 7 and it sometimes just locks up and wants to go up and down , even when I try to move in any direction . Sorry for the hijack mate
Sorry mate I should have been a bit more clear, basically if I where to move the mouse in any direction it would jump around the screen very erratically and it would also occasionally lock up like you mentioned, I dont know if the problems I described are present in only the RAT 9 but Id be curious to know how it behaves for you in the future and see if mine was an isolated case but considering you having sensor issues too I dont think it was.
Even with all of its customization I could also never find a comfortable position for my hand when using this mouse obviously everyone has different sized hands, mine being of average size, so others may find it more comfortable.
How long have you had yours now?
