Thanks for the Witcher 2 video. Ubersampling is way too intensive. Personally I don't notice the difference with it on and it's not apparent in videos either.
Have you got Vsync disabled in the advanced settings? I couldn't tell the difference until I noticed I had Vsync enabled and realized my FPS was being limited.
I mean visually. I have Vsync turned off. Do you see a visual difference with it turned on (ubersampling)?
Oh, I thought you meant performance wise. There is a slight difference, things seem a bit more shiny and smooth looking with it on but not that much more that it is worth the FPS you lose.
How do you think a 290x Tri-X OC card would do against your 290? I haven't found any reviews for it when i looked a few days ago? You think it could tame the hotter core and still be quiet?
I would give or take a few degrees obviously but then again if it clocked to the same as the 290 versions i wonder how the performance would scale. They should also theoretically clock higher as well because they made the 290x grade. But who knows.
I've seen some reviews of the 290x version and it does really well with the chip, better than the asus one easily. The main issue with them is price. They're still one of the cheaper ones but still the 290x is too expensive.
Shadowplay is better than BF4 easily, its just shadowplay is a bit overrated imo.Hey SieB good job on doing this but did your card come with BF4 or if it doesn't I'll just go with 780 cuz of Shadowplay.![]()
Yep :l. I'd have bought another 280x by now but they've gone up in price too much. The 290 is going to outsell the 290x easily imo.Stupid retailers and bitcoin fanatics![]()
The card does indeed come with BF4Check with the retailer before you buy though because they might not all come with it, but from OCUK they do.
There is an alternative to Shadowplay using Bandicam. It does the exact same thing Shadowplay does on Nvidia cards and uses the GPUs built in H264 decoder. All the vids in my tests except for The Witcher 2 were made using it, only down side is it's not free. Well, you can use it for free, but with the free version you are limited to 10mins of recording and you get a "www.Bandicam.com" watermark on the vids.
All details here
http://www.bandicam.com/support/tips/amd-app/
However, AMD are working on their own version of Shadowplay with an upcoming all new version of Radeon Pro called Radeaon Pro Infinity. So sooner or later there will be a free option for a Shadowplay alternative with AMD cards.
http://www.radeonpro.info/2013/08/get-ready-for-new-radeonpro-infinity/
Thanks!Then I'll go for R9-290 I'll order it now so I can get it in the middle of the next week!:lol: Infinity looks cool but it's still in dev...:dammit:Anyways thx for helping me decide which team 2 chose! Cheers!
EDIT:
Ooh btw I'm from Bulgaria not UK!![]()
