Hello peeps!
So this is basically my Phantom that i use everyday for gaming
Just a few quick snap shots on a reallt urd camera, doesnt pick up LED's all that great.
The specs are as follows:
Asus P8P67 Rev.3
I5 2500k @ 4.6ghz 1.34v
Corsair 8gb vengeance @ 1600mhz
XFX 7970 Black edition @ 1125mhz & 1575mhz
Corsair AX750
2 Samsung 500GB HDD's in Raid 0
Corsair Force 3 120GB
The watercooling is as follows:
Phobya v1.2 G changer 60mm 360 RAD
Phobya Balancer 150 Reservoir
EK 7970 Full Waterblock
XSPC Raystorm CPU block
Swiftech Laing D5 pump, I have mine set on 4.
Alphacool D5 pump top
9 Bitspower 1/2" Barbs
1 Bitspower 90Degree swivel 1/2" Barb
2 Bitspower Blanking plugs for the Pump top.
Mayhems Nebula blue coolant.
7 120mm Bitfenix Spectre Pro fans.
I have a few things i want to sort out before i can say its finished, a Window being one and also doing something with the optical bay i cut out to fit the Rad. Its a shame i couldnt have put all 3 rad fans up top but it would mean removing the USB's and fan controller which i didnt want to do and ruin the look of the case on the outside.
I cant get the camera to take very good pictures, il get my Uncle to take some with his proper camera as these just dont do it justice :/
And one with flash, was the only way i could get a clear pic of the inside without the camera having a fit at the LED's lol
Asus P8P67 Rev.3
Corsair AX750
