Hi,
In the next 2-3 weeks I will building myself a new gaming computer.
I will post the list of the parts a plan to get, i just need some help and inputs on the parts I've selected. My budget is $2800 USD (including mouse, keyboard etc). I'm under that by far so I'm quite happy, although it would be good for you guys to have a look and suggest better parts (not necessarily cheaper). I will also be over clocking my CPU to around 4GHz on occasion.
Parts list
CPU:
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Intel Core i5 3570K 3.4Ghz Socket 1155 Box[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]GPU:[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]EVGA GeForce GTX 680 HDMI DisplayPort Dual-DVI 2GB[/font]
RAM:
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Corsair XMS3 Vengeance DDR3 PC12800/1600MHz CL9 4x4GB[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]MOBO:[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Gigabyte GA-Z77-D3H[/font]
HDD:
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Seagate Barracuda ST1000DM003 64MB 1TB[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]SSD:[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Intel 330 Series 2.5" SSD 120GB[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]CPU cooler:[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Corsair H100 Hydro Series[/font]
PSU:
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Corsair CMPSU-650HX 650W[/font]
Fans:
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Cooler Master SickleFlow 120mm[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]*[/font][font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]EDIT I will be getting three of these[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Chassis:[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Raidmax Platinum (Black)[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]Any other information needed feel free to ask. Not sure if build works so have a look guys/girls
.[/font]
[font=Tahoma, Arial, Geneva, Lucida, Helvetica, sans-serif]P.S I know this is overkill but i may be getting a second 680 in the future[/font]
Parts list
CPU:
RAM:
HDD:
PSU:
Fans:
