My Mozart Watercooled
The case does look very good for a Thermaltake, I like the Mozart quite a bit actually. It looks nice and neat too....excellent job. Now what are you going to use the three pumps for? Obviously first is CPU and NB, second will be GPU and....? Third? Nice job regardless cuprasport :)
Just noticed you got 4ghz out a E6600:eek: . On a P5N-E SLI as well!
You mod the board at all? or just a godly chip?
get.php
Looks Gooood m8
one thing i would do tho place a nice piece of wood under it cut down on the dust being sucked in from carpet.
it took 1.75 volts (loads of pencil) highest i got was 4.05ghz so its not a godly chip shame really
all the intake fans have filters so it doesnt get dusty inside the case at all.. i do intend on putting some 120mm fans on the acrylicy parts of the door's and i will filter them too
i have my gpu loop in an dchanged to a p35 board but my cam was in england at the time so i didnt take any pics but im stripping it all back down to add my 3rd loop in so ill keep the build prosess goin
heres is the front of my case so far for a teaser
any ideas on a colour for my 3rd loop ive been thinking purple but im not 100% sure.. id love red but feser1 looks pink
little update (sorry theres no pics yet)
ok now have everything here apart from 1 rad as i need to find one that will fit int he gap without going for a 120.1
here is what my 3 loops now consist of
Loop1 Cpu
Alphacool Laing DDC 12V ULTRA Pump & Plexitop
Thermochill PA120.2
XSPC Bay Reservoir (Black)
D-TEK FuZion CPU Block
Loop 2 Gpu
Thermochill PA120.2
EK-FC8800 8800 GTX - Acetal
Loop 3 Chipset
Still need to find a rad to go here
2x EK-NB/SB ASUS Chipset Block's - Acetal
All loops have feser 1 Green, Blue + Purple
Masterkleer 7/16" ID (5/8" OD) PVC Tubing
YATE LOON 120mm - D12SL-12 UV Blue Frame with 4 Blue LEDS (2 on each rad
YATE LOON 120mm - D12SL-12 with four blue led (2 on each rad)
Plastic Tubing Clamp's
i did have shrouds on 2 of the rads but as my case has 16 120mm fans + 1 80mm fan the noise diffrence couldnt be noticed so i took them out
i promise i will update with pics as soon as i have my last rad (hoping next weekend tbh)
the question i have is would you add mosfet watercooling with the following
Thermochill PA120.1
2x ek Asus Mosfet blocks
or do you think thermalright HR-09u's will be ok (already have 1)
also if i do use water what colour feser 1
shrouds do help with noise, h/e they help if you are pulling air through the rads. they do help with push too h/e not as much as a pull config, so if ur pulling air throu it id suggest you put em back on. um i dont think mosfet cooling is really necessary a good heatsink should do the job, but if u have the space and cash, y not slap some EK's on em.
Ha! Thank you a Thermaltake case on here at last! AND ITS HUGE! And Jesus thats such an overkill of watercooling but its so BOSS!! Amazing build man amazing.
How much noise comes out of the case? or is it pretty quiet.. lol.. Looks great what you have so far tho!!
