cuprasport
i water cooled my mozart even tho it still isnt finished here it is so far
the cooling potential for this case is amazing even though thermaltake are not known for the best cases ever this case is only 36cm from front to back and with it having the ability for 5 front and 5 rear 120mm fans there should be good airflow
thats the inside of the narrow side
that is the backplate off the mobo tray doesnt come off but with the back off its alot roomier to get in there
Not the best pic in the world but you can see the mobo tray and the fans on this side
ok im watercooling my system in this case so here is a log of whats happening
