tc_overclocker
ok... so i've had a few prommies in the past 6 months but this last one has given me the most headaches...
This was a prommie that I bought pre-modded to r404a, the Mach I version.
Now everything was running smoothly apart from the odd 'heavy' plinking, but now i have problems..
When i boot up the prommie just with the head loose, the temps slowly crawl all the way down to -49C... from then onwards the evap. head temps slowly climb, remember this is with the head loose so no load.
I booted it up maybe 10mins ago and it crawled down to -49C and has slowly crawled up2 -38C over the past 10mins, and it's still climbing... Now I know it's not a leak because the prommie has been sat turned off in the corner of me bedroom for nearly 4 weeks now and it still does the same..
The only thing that is odd is that the compressor doesn't get as hot as it used to, but the drier is absolutely boiling?!?!? so much that I can't touch it wivout burning meself. Could I have pinched the cap tube along the line anywhere? would this cause this problem.
All I know is, is that I have a Prommie Mach I sat here doing nowt, cos it won't last 20mins attached to a rig before evap. temps reach -26C and the prommie starts screaming at me.
Please help.... I don't want a dead prommie on me hands
