^ This is a pic of the main room area type place..
^ It's dark around the corner
^ If you play the map it won't take you long to find the Fire Hall
^ I won't tell you how to get here..
^ I won't tell you how to get here either.. You might just stumble in upon it! That looks like solid wall at the end doesn't it?
And finally there is one room that isn't listed here, there is only one way to get there and I'll give you a clue: You need clips to fire guns, what if you don't have a gun.. how many clip do you need?
You can download the map here.
