Sweet build mate, super tidy cable managment
Simple, tidy and clean. 10/10 mate
Looks great! all you need now is to mod the matrix light cable so the low load colour is redHow are the spectre pros? was thinking about getting them for mine![]()
Lol, i did mod the matrix ledsi made that little guide on here.![]()
the spectre pros are really nice, at 12v they are not silent, but not many fans are. I think they are worth it because they look SOO nice, so if you have any visible fans i would recommend them![]()
Oh yeah - crapI have loads of visible fans
especially now i have fans in the window (check my rig) I was thinking about getting some good looking ones for the window- also do they have braided cables? kinda important for the window (also long cables?)![]()
Yea they have braided cables for sure, but i'm not sure on the length i'll have to check it, i'll let you know
K sorry for taking so long, school's been taking up loads of time.
i just pulled out a ruler to the back of my case, and the cable is 47 -+ 3 cm long. and to clarify G-Dubs was 100% correct, the cables are BLACK, not braided my bad, you can see the cables in one of the earlier pics when i showed the fans and what it came it.
Wow. Bloody nice rig you got there dude (no pun intended...okay maybe a bit). The only thing I could see that would make it better would be to put the black PSU shroud that came with the case over the end of the PSU, to hide those pesky yellow connectors
. Other than that, 10/10!![]()
