I want to replace the front 200 mm stock fan on my 600t se. Was looking on newegg to buy the Xigmatek XLF but the reviews said it only comes with mounts to set it up as an exhaust fan. What did you do to mount it in the the front of the case as an intake? And is it quiet?
Sry for not replying mate, just hadn't had the time to login over past few months.
The Xigmatek fan is ok, as for mounting I got a little creative with some black rubberised garden wire, so not only did it hold the fan firmly in place once I tied a knot in the 4 corners, but because of the rubber coating the was little to no vibration noise
. The fan is very quiet, but didn't shift enough air for my liking, so after a month I pulled it out, removed my hd cages and put and old red Coolermaster Megaflow in, and it made a huge difference to the airflow.
I'd higly reccomend taking that route and just moving 1 hd cage over to just infront of the psu (provided there's room of course
I've changed a few bits and pieces, so I'll be posting up a few pics as soon as I get time over the next couple of weeks
