My 600T white Rig
stinger53
Specs of build are:
Cosair 600T White
Antec 750w True power
MSI Z68A-G45 G3
Intel i5 2500k
Antec 920 cpu cooler
8gb corsair vengeance blue
HIS 2GB 6950
Samsung Blueray
1TB HDD
still plan to get some white extension cables. a SSD and some white fans on the 920
It's a very nice case ey?
white extensions would be really good indeed ;-) or sleeve the entire psu if you're up to it
I'm gonna give that a go in my 600T I think ^^
looking good mate...
as mentioned before white extensions would be the icing on the cake :)
You really need to do something with the cable management there. If it were me I'd not even turn my setup on till I've dialed all the cables down to every last fan connector. There are definitely better routes for some cables, especially the PCI-E's.
Nice start, you should remove the HDD bay completely and mount your drives in the spare optical drive bays as you will allow for greater airflow around the lower part of the board etc.
