My Upgrade Path
sedontane
Back in 2008 I built my University computer, It's been upgraded in a mish mash way ever since, usually on the super cheap (e.g the mobo/CPU, £1 when my work upgraded some machines a few years ago).
Anyway, its time to truly do it justice. I'm thinking a tiered upgrade plan.
Stage 1: Core elements
Stage 2: New Case/Peripherals
Stage 3: Water cooling loop/M.2 drive
This is my current mish-mashed pc:
(obligatory image is coming)
A list of my current PC
CPU: Intel Core i5-750 2.66GHz Quad-Core Processor
Motherboard: ASRock P55 Pro/USB3 ATX LGA1156 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (£73.13 @ Misco UK)
Memory: Kingston 4GB (2 x 2GB) DDR3-1333 Memory
Storage: Kingston HyperX 120GB 2.5" Solid State Drive
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive
Video Card: Asus Radeon R9 270X 2GB DirectCU II Video Card
Case: Antec Nine Hundred Two ATX Mid Tower Case
Power Supply: Corsair 750W 80+ Platinum Certified Fully-Modular ATX Power Supply
Sound Card: Creative Labs Audigy SE 24-bit 96 KHz Sound Card
Wireless Network Adapter: TP-Link TL-WN851ND PCI 802.11b/g/n Wi-Fi Adapter
These are the parts I'm considering for Stage 1. My budget for this stage is ~£1k, but every penny saved is a bonus, so I've plumped for an i5 instead of the i7. Changed ut the 1060 for a 1070, as per reccomendations
Stage 1
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor (£230.99 @ Amazon UK)
CPU Cooler: Silverstone TD02-LITE 92.5 CFM Liquid CPU Cooler (£77.99)
Motherboard: Asus STRIX Z270-E GAMING ATX LGA1151 Motherboard (£199.38 @ Ebuyer)
Video Card: Palit GeForce GTX 1070 8GB Super JetStream Video Card (£399.93 @ Amazon UK)
Total: £981.42
For Stage 2 I really like the look of the Nvidia GeForce special edition InWin 303 case. But I dont like the window with the garish white text.
InWin 303
Unluckily, it also seems the Nvidia Special is currently only available as a pre-built solution from PC Specialist :sad:
Stage 3: The Pipe Dream
I'd like to water cool it, probably hard tubing, and install an M.2 SSD, with a fast controller (>SATA, 3Gbs speed), but I think that's a H2 2018 goal.
I'm interested to hear peoples opinions on any of this.
most definitely wait for ryzen and possibly vega, you may also find better prices at Aria or ocuk
If you're not overclocking, you could save some coin on the CPU cooler. A cheaper air cooler will work great on stock speeds, even OCed a little. It won't be much, but it would be something. I'd also echo Aliens suggestion of a 1070, if you can swing a cheap one.
