My 580 lightning overclock
cbiltsouris
hey guys
ive been playing around with the lightning for a couple of hours now and this is what I got
http://img151.imageshack.us/i/screen5ti.png/
I havent overclocked the mem yet, im pretty sure I go above what Im at now but tbh Im happy with it for now
Looking good
Is it a suicide screenshot or can you bench at that speed?
Im still waiting for my Lightning card it should be here maybe tomorrow i hope.
nah thats my everyday speed from now on
gotta oc the mem which ill do tommorow, i can go higher on the core
but im happy with the oc atm,getting around 73 - 75 max temp wise
You lucky SOAB. Can't push mine past 960 core or 2320 mem. Have you got it under water?
P.S. Fancy benching for OC3D? I managed to get about 6 points at my clocks you could probably get plenty more.
i can go to around 1108, but im not gonna because of heat and my paranioa I have sometimes lol
what volts are you doing? Ive got 2100 for the mem whichI havent touched yet nah just the normal lightning no wc. next to bench the other 460 hawk and then wait for my asus to come back.
I've got max everything on volts in Afterburner. Haven't touched the voltage switches on the card though because I know if I do that I could set the voltages high enough to kill the card. Have you done that?
welll max voltage for me is 1.149 havent touched the switches on the card either and to be perfectly honest im not going to.
maxed everything out? like in afterburner you have set the core voltage to 200? thats alot. im on 143 atm
Yeah, was told by marsey in another topic that although I can probably run it with less I can max the voltage out without damaging my card.
Just haven't gotten round to trying to lower them yet. I'll do that when I feel like it.
