Madmullen
Hi guys, well the time has come to see if my rig comes up to your standards.
I had Xcase case last year and upgraded a couple of parts Brd,Chip & Mem but I`m a bit of a tidy freak and wasnt happy with the way it looked and performed. I needed to have a rig that could take a good bashing as my grandson like Racing Games but also 1 my wife could also use with no hassle ( press the on button ).
After checking a lot of Tom`s reviews I decided to do another upgrade didnt have bundles of cash (I luv`s my wife ).
There are a couple of items I would have liked to have got but dosh has gone for now(SSD`s), also I like your opinion on the positioning of the H105, its runing push pull using the orginal 140mm fans to push not sure if it looks good or not.I did have it running push pull with all 4 120mm fans 2 either side of the rad and connected on the inside only.
He is my spec:
Case:Corsair Osbidian 750D
Motherboard:Asrock 990FX Extreme4
CPU: Amd FX(tm)6300 six core Black Edition 3.5Mhz (not clocked yet)
Ram:Corsair Vengence 16GB Dual Channel @ 1600MHZ
Graphics: 2 X Asus Gefore GTX660 1020MHZ 2GB PCI Express 3.0 HDMI Direct CU II OC runing in SLI (not clocked yet)
Sound: Onbrd
HDD: Baracuda 1TB
HDD: Toshiba 250GB
DVD: LG Lightscribe
PSU: Corsiar RM Series 650W
Aerocool X-Vision 5 Channel LCD Fan Controller
Cooling: Corsair Hydro H105 running in Push Pull (Corsair 2 x SP140mm,
2XSP120mm)
Corsair 2 X SP120mm and 1 SP1400mm all exshust.
He is my spec:
Sound: Onbrd
HDD: Baracuda 1TB
HDD: Toshiba 250GB
DVD: LG Lightscribe
2XSP120mm)
