msn key logger
cybermaniac
hey guys.
I need a keylogger for msn.
A friends' gf has been asked by her mother to keep an eye on her sisters' msn conversation so I just need to find something that is decent
cheerz
lol thx(!)
not very useful considering i've already DONE that.
I was enquiring on people's personal experience with them.
So please, next time you tell me to google, please consider my intelligence and don't insult it.
I've used a few for private clients to keep track of various employee's and mostly wife's :(
The one thing I found was most get picked up by good antivirus software. Fortunately some I worked on had mcafee tho, which meant it wasn't found at all.
I'd guess you could just set the working directory into a good antivirus' ignore list tho :)
A lot of them are hit and miss tho, I mostly just tried and tested lots until I found the best.
The best resource in looking into a legal keylogger is - http://www.keylogger.org/
From memory, the ones I have used -
stealth keylogger (this one wasn't picked up by mcafee)
spytech spyagent (quite stealthy, altho saved screenshots were easily found - also very bloated which results in high memory use)
allinone keylogger (really didn't like this one, seemed buggy and crashed a lot)
I probably tested a lot more, but those are the main 3 I actually remember using. Private keyloggers are obv a better way to go, but you need to be in certain trusted communities etc. Also maybe overkill for checking someones msn (unless they actually know a lot about computers)
once you have finished with it tho, uninstall and make sure you run a good antivirus and something like spybot s&d (almost all are picked up by spybot s&d)
she is about 14 or 16 something like that, chances are she's already got msn plus, damn kids are getting more and more tech savvy and less and less people savvy (she has the issue of trusting any person in a chat room/msn room)
Just enable logging of conversations by messenger?
/mod hat
Keep it legal and within the rules people. We ware watching you.
Just block anything other than port 80 on the router, followed by a healthy blocking of all messenger related websites in the filter options tbh ;)
Ham's idea might work if she's just an average user :) would also save putting on extra software.
The main function I found usefull in using keyloggers was periodic screenshots, as they showed more info and were a lot easier to show clients etc.
The only problem with a lot of keyloggers is memory usage and system slow down.
The MSN logger works a treat. Set up multiple user accounts on the PC (For example VK and Jim) enable the logging in the "options" menu of Jim's MSN and set it to save to VK's documents.
At least, that's what I do.
