MSI Afterburner 2.1.0 Final out.
SnW
Link to download...
http://downloads.guru3d.com/Afterburner-2.1.0-Final-download-2562.html
MSI Afterburner (easy) Voltage unlocker...
http://www.mediafire.com/?chzic7824iwxnd4
I have a GTX470/460 in one rig an now the Voltage goes up (for both) to v1.4
I thought the beta could drive it upto 1.5??
Not sure if this is the case with a single card or of the same gpu chip,
i am using 2 rigs with mutiple GPU's and mixed GTX470's and GTX460's and with the 2 different GPU chips i can go up to v1.4 (with the voltage unlocker).
Ok that voltage unlocker is sweet!
My EVGA 570 would allow 1.1 but these cards can safely take a tinsy tiny bit more from what I've read.
Maybe its because mine are GTX580's but I didnt think it would make much of a difference (although 0.1 in voltage isnt much of a difference
Can't you take the voltage unlocker up to anything you like by editing te ini file?
Edit: Just checked and mine maxes out at 2.0V... Obviously didn't apply it.
I take it you moved both the MSIAfterburnerVoltUnlock.exe and the MSIAfterburnerVoltUnlock.ini files to:
C:\Program Files (x86)\MSI Afterburner (or equivalent on your PC)
In the MSIAfterburnerVoltUnlock.ini, open it with notepad and change the txt below that I make bold
; MSI Afterburner Max Voltage Unlocker
; by AgentGOD
; Home Page: http://www.ultimate-filez.com
; Donation : http://www.ultimate-filez.com/?page=donate
; NOTE: you should carefully read the readme file before using this program
; Specify your desired maximum voltage here in mV (millivolts)
[Afterburner]
; a very conservative default max of 1.4v has been used here for safety
NewMaxVoltage=1400
; default max boost voltage is set to +500 mV for safety
NewMaxBoostVoltage=500
I have tried that and it is looks like this:
; by AgentGOD
[Afterburner]
NewMaxVoltage=1400
NewMaxBoostVoltage=500"
but i cannot run it.
Ok got it, I had to run as administrator.thanks
So you can now up the 1400 to whatever you like... Well when I entered 3000, the Afterburner still topped out at 2v.
