L Lexxikonn New member May 11, 2011 #1 Im thinking of buying a MSI 6950 Twin Frozr, but it comes in two versions, the II (2) and III (3)... Is there any difference between the cards? You can find them both on Scan UK...
S SmoulderingCircuits New member May 11, 2011 #2 The TF III is a bit better i think but my TF II never went above 50 under load so doesn't really matter which one you get
L Lexxikonn New member May 11, 2011 #3 Good news, since they are both the same price, might as well go with the TF III
Karlos_the_n00b New member May 16, 2011 #5 I heard that you can use the 6970 BIOS trick on the TF 3 but not on the TF 2. http://www.techpowerup.com/reviews/MSI/HD_6950_Twin_Frozr_II/32.html http://www.techpowerup.com/reviews/MSI/HD_6950_Twin_Frozr_III/27.html
J jack-uk New member May 16, 2011 #6 I think they both have similar clock speeds. The II shaders wont unlock but the III will so i would go with the III.
S SmoulderingCircuits New member May 16, 2011 #7 jack-uk said: I think they both have similar clock speeds. The II shaders wont unlock but the III will so i would go with the III. Click to expand... TF2 definately doesn't have a dipswitch for dual bios. Don't know about TF3
Karlos_the_n00b New member May 16, 2011 #8 Fodr Kreatr said: TF2 definately doesn't have a dipswitch for dual bios. Don't know about TF3 Click to expand... Really? Might be a custom PCB then which would be part of the reason it won't unlock I guess.
S SmoulderingCircuits New member May 17, 2011 #9 Karlos_the_n00b said: Really? Might be a custom PCB then which would be part of the reason it won't unlock I guess. Click to expand... I had one. It is
