Jeremy1998
Well, I'm seriously considering building a Mini-ITX file server. I want to use 4 fast hard drives in a raid 10, to create a rather small, but pretty speedy network drive. I am debating what motherboard and CPU I would need for this. I want to run it off the chipset, because I will be using a NIC card in the only PCI-e slot. So, what chipset (Intel Z77, or AMD APU chipsets) will have the best performance for raid 10? Can you also list a board with maybe 5-6 sata ports, so it can plug in the raid drives plus a boot drive or 2. Also, what kind of CPU power is necessary for this application?
