mixing radiator widths ok?
katiekitsune
so im stuck between two options for my top radiator in my define s, the alphacool st30 280 mm and the EK-CoolStream PE 360. i will have an EK-CoolStream CE 280in the front and a third 140mm fan also mounted on the front. im just cooling a single gpu and cpu (possible sli further down the road) and have all the fans i need for either config. if it helps im using an ASUS ROG Maximus VII HERO motherboard (if i can get around those radiator thickness limitations i will get an EK 280 for the top to save some money)
Its wont matter at all, a personal thing for me though would be trying to keep the brands the same so they just look like the same rad range.
