Mini Desktop PC Build Advice
Lexxikonn
Hey dudes, you guys have helped me before, so I might ask for some more help again...
My old gaming rig is now being used as a family computer and I think the levels of hardware and power which it possesses are not necessary for its purpose.
So I want to build a mini desktop PC, either Mini-ITX or Micro-ATX, but I dont have a clue where to start....
I want the PC to be small, quiet and cheap (<£400 preferably). Power is not really a priority, but I do want to put a separate graphics card inside (albeit a very dated one).
Can anyone recommend me:
1. A suitable motherboard and processor.
2. A suitable case for said motherboard.
3. A suitable graphics card and power supply.
Thanks for the help
Case fractal design core 1000 https://www.aria.co.uk/Products/Com...1000+Black+Micro-ATX+Chassis+?productId=45751
Intel i3 2100 https://www.aria.co.uk/Products/Com...t+LGA1155+Processor+-+Retail+?productId=43839
Evga z68 matx mobo https://www.aria.co.uk/SuperSpecial...DDR3+PCI-Express+Motherboard+?productId=46894
be quiet modular 530w https://www.aria.co.uk/Products/Components/Power+Supplies/Modular+650W+or+less/530W+be+quiet!+Pure+Power+L8+80PLUS+Bronze+Modular+Power+Supply+?productId=46237
Evga 1gb gtx 460 http://www.scan.co.uk/products/1gb-...shader-clock-1526mhz-336-cores-2x-dl-dvi-i-mi
comes to £393ish but do you need ram and a hard drive as you did not put that down?
So you think going down the Micro ATX / Mini ITX route is a bad idea? I had always considered just making a normal ATX PC in a small case, but the space I have would suit a HTPC really well if you get me.
I have a stack of 5 or so 1TB Samsung Spinpoint F3's which I bought for £29.99 each before they got expensive.... Best buy ever!
No m-atx does it job if thats all you need, i did put up a m-atx mobo
it really depends on the space you have, that mobo would even allow for an sli setup but would need a different psu
