me again - card advice
its well worth a try FEAR if you no how to do it, on the downside you will probably fuxx your card but on the positive you have a 7800gtx
just check on the internet you will usually find guides on how to flash safely. i myself have flashed he card many times and i fucked it once but still i got it to work
just to throw that in : XFX is also very good ;)
I wouldnt play around with a 400 € Monster if I were you but ok if you like the risk try to flash it to a 78 GTX ;)
you cant fuck the card by flashing it, all you have to do is flash it back and it'll be fine. just make sure your card can handle gtx clock speeds before doing it, if the pipes are broken just flash it back and overclock
but what happens if he cant start anymore with the card because the card is not able to display anything ? I would be veeeery carefull with bios flashing.
Easy, boot up with a PCI gfx card with the 7800 still in there and flash that way. Plus that would only happen with a faulty bios or something
Anyone know where in the UK sells this card?
EVGA e-GeForce 7800 GTX KO ACS³
