bloodthirst
FEAR flash it to a gtx
name='NickS_' said:I was posting at the same time as Eguy I guess, because when I pressed reply...it wasn't there...enVias.
name='harmonicgenerator007' said:FEAR flash it to a gtx![]()
name='harmonicgen007' said:its well worth a try FEAR if you no how to do it, on the downside you will probably fuxx your card but on the positive you have a 7800gtx
name='FalconFX' said:but what happens if he cant start anymore with the card because the card is not able to display anything ? I would be veeeery carefull with bios flashing.
FEAR said:Anyone know where in the UK sells this card?
EVGA e-GeForce 7800 GTX KO ACS³
