mcp655 and ek d5 xres
Maybe I needed to clarify the actual questions better....
Will a 1.5" thick 360 radiator(20fpi) by Koolance with a mcp655 pump, rasa water block, razor water block, and 140 resevoir with 3 cooler master 2000rpm sickle flow fans be enough to cool a overclocked 4.0+ range I7-950 and a 6970(load temps stock 70ish)??? Any thoughts?
NEVER MIND, I FOUND A BUILD USING ALMOST EXACT SAME PARTS!!!!
Only difference is a 580gtx . His temps are awesome with 4.2 ghz. SO sorry for this thread. Any comments or suggestions would be welcome. Thanks!
