Critical employees abandon EK Water Blocks amid financial issues
Booo boring :D
I'm currently chatting to Lily on Skype about a block for my 6950XT !
Just FYI, Lily is 70% on that account. The other 30% are different contacts who "pretend to be" lily. They still give the same generous discounts from Bitspower though.
I see !
Well hopefully -
1. It fits. It is listed for a 6900XT reference but I am 99% sure that is the same as the 6950XT MBA and
2. I can get a discount 'cause it's reallllllly expensive :D
perfect timing for me that I abandoned the world of watercooling.
I just need to put it online for sale now.
I have a load of rigid tubing, fittings and tools all sat in a box that I have not used, all still unopened from Scan.
I now have no interest in using them now because, my CPU if I upgrade, I will probably get a Hyte AIO because unlike Corsair etc, they understand you need thicker rads to cool cpu's these days.
My GPU hasn't gone above 75c iirc since I bought it on and I have not needed to ramp the fans up.
But in the back of my mind, I am also thinking if I upgrade then I will buy a GPU with a block attached already and then buy a Silverstone rack mount case and watercool that and possibly use it.
I probably should sell the watercooling stuff I have but I just have not got round to finding it all and then listing it and finding prices etc is just putting me off at the moment as well.
