Does anyone know the max HDD size you can use on a MSI P43 Neo-F?
On MSI's website max hdd size they tested is 750GB and I see there is a bios update to support 1TB but nothing about the max size you can use.
Update: bought a WD 2TB black drive and it works just fine, no bios update needed.
Edit: aparently I was already on the last bios version but I don't remember updating...
