MadShadow's Build
MadShadow
Active member
Alright, so Im asking for help again when it comes to picking the parts I am going to buy. I think I've got a fairly solid list, but Im looking for some approval/criticism/comments on my choices. It is just meant to be a gaming build really. Im not planning on streaming, editing, or anything of that nature.
Specs:
PCPartPicker part list: http://uk.pcpartpicker.com/p/sWjDTW
Price breakdown by merchant: http://uk.pcpartpicker.com/p/sWjDTW/by_merchant/
CPU: Intel Core i5-4460
CPU Cooler: be quiet! Dark Rock 3
Motherboard: MSI Z97S SLI Krait Edition (Ive got a bit of a white/black thing going right now)
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Crucial MX100 256GB
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card
Case: NZXT S340 (Black) ATX Mid Tower Case
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Total: £770.90
Im fairly sceptical about that GPU as it is only priced at £200 and it even comes with a backplate. is it too good to be true?
By the way, please dont recommend a 212 Evo, as I went with the Dark Rock 3 purely for the looks.
Thanks guys!
Looks pretty good actually, well balanced!
What about a 4690k with a stock cooler for now though? Then you can get the BeQuiet! heatsink later.
Edit; PowerColor have been around for ages and I don't think they're that bad, although I have no personal experience with them.
Not really reference Powercolor 290X's were £209 last year. I've no idea how good that cooler is but I would imagine it's 100% legit.
JR
http://uk.pcpartpicker.com/p/LHHg4D How would this work for you if you swapped the 280x for the 290 you've found? (Although especially with used 290s..... I wonder how many hours has it been on running 100% minining coins...)
Tbh I really want to go with the Z97 platform as I may want to upgrade to a top-tier i5 in the future. Thanks for the reccomendations though mate ;)
Holy shit man, thats actually a great idea! I didnt even consider that at first, but it seems ideal now
JR
Okay thanks. I guess Im going for this 290 then ;)
JR
http://www.overclock3d.net/reviews/gpu_displays/powercolor_r9_290_review/1 ;)
AMD Stock cooler is well shit though! What about getting something like the Raijintek Morpheus? Although the grey heatsink would ruin the perfect black/white balance.
Edit;
This is a 290x review, but it does have the PCS+ cooler on it:
http://www.overclock3d.net/reviews/gpu_displays/powercolor_r9_290x_pcs_review/1
Come on Feronix dude, what if the guy wants to actually have a jetplane in his room though and wants to see if his PC actually can take off?, then he's well on the right track :p
PowerColor's PCS cooler is pretty good, can be a little noisy but noisy in the Nvidia reference way, not amd reference :P.
Edit;
Well if Tom's happy with it, I suppose I will be as well
I think it will be alright for the first few weeks or maybe months. If needed, Ill just underclock/undervolt the card untill I can get a better cooler.
Alright, I guess I can deal with a little noise. Ive only got a laptop now and that gets pretty loud, so Im used to it ;)
If you can find an XFX card you might want that instead, its a bit quieter (but a little bit warmer running) and would fit your build much better.
Then get an aftermarket or used one :p I'd rather have a better GPU then an ever so slightly worse one that has a backplate
I'll have a look at what ColdZero has for that card. If there isn't a backplate, I'll ask Patuga if he can make one for me ;)
Edit: Sorry for those who clicked on this thread thinking it was a build log :p
That's what I was thinking. I don't mind it its a bit louder than the XFX card. I don't really want to go XFX because of all their problems with VRM cooling.
They seemed to have mostly fixed it since launch. There were quite a few with the first reviews but they seemed to have done a distinctly un-XFX thing and release a card with a fix.
I'd go for the XFX card if I was getting a 290x as their top of the range one has a lot of improvements. Since it is a 290 I'd probably go powercolor.
There's also a brand called VTX 3D which is a powercolour subsidiary. Ther 290x is cheaper than a 290 made by other brands
