Hi, im new here, but ive been toying with getting a phase shift for a long time... however i have a Lian Li PC-73SL, which i do not want to mod, cut or anything... if you have a look at the pics i will attach would you be able to put the tube out the 80mm fan hole to the left of the cpu socket? would it be flexible enough to do this?
Also i was reading on the vapochill site that it makes about 36dB noise, what sort of noise does the Mach2 or Mach2 ST make, im ideally wanting to keep it under 30dB as it will be running 24/7 (if anyone has any views on it being on 24/7 this please can you tell me them)?
Thanks
N4N01D
Thanks
N4N01D
