evolutionsentra
I know for a fact my evaporator temps are too high. It gets down to about -44c then levels off at -36c after a couple hours. from what I read it should read in the negative 55-70c range. I know it's not a leak otherwise it would discharge faster. The system has been throughly cleaned of dust (fan blades and heat exchanger). What could be causing this problem?
Even if I had bad contact on the CPU head, shouldn't the evap. head still stay really cold?
