Hey,
I need some help here. I just got a prometeia Mach II (a regular one, not GT and not ST) from kit-tronics. I'm using an IC7-G MAX II and a P4 3.2E Prescott cpu. At stock speeds (3.2Ghz) I am getting an Idle cpu temp of about -6C and when running a benchmarking utililty it jumps up to around 30C with prometeia reporting -49C. When overclocking to 4.0Ghz at 1.5875 V the sensors indicate Idle at +6C and load at +50C - prometeia reports -41C. This doesn't seem right to me. Also when running superpi, a second after starting, motherboard monitor shows a huge increase (25C) almost instantaneously. When opening microsoft word 2003, it jumps from 6C to 16C. These sensors are the ones built into the motherboard. I have pretty high ambient temps such as 40C case according to bios if this is effecting it. Could I have a bad contact and how can I tell? With my cpu kit installed, I cover about 90% of the processor, missing just the left sliver. Also, there is a hole in between the evaporator mounting clip and the upper mounting bracket after the head is in place. In other words, I can see straight in through that hole to the motherboard. Maybe I have it installed incorrecty? Also, what kind of temps and speeds should I expect from my current setup? Lastly, I have heard that you can add temp probes to the mach II - anyone have any info about where to get them and how to add them so I can get true temps? Any advice would be greatly appreciated. Thanks!!
